Ga door naar hoofdinhoud
The PowerBook G4 Titanium Series was initially announced at Steve Jobs' keynote at MacWorld Expo in January 2001.
Will LCD from a Mercury work in an Onyx?
Will the LCD assembly from a 400 MHz Titanium Mercury work in a 550 MHz Titanium Onyx?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I finally got a used Mercury laptop for cheap. It had a bad logic board. I can confirm that the logic boards and keyboards on the Onyx and Mercury are not interchangeable. The Onyx uses PC 133 RAM so it can be used in a Mercury (PC100) but not vice versa. However, I was able to successfully transplant the Mercury's LCD assembly into the Onyx and now I have video. The optical drives, modems and hard disks are also interchangeable.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Since they have different part numbers I would think they are not acceptable swaps, but wait for Ben to be sure. Mercury 661-2539 Onyx 661-2568 Ralph
Score 1
1 Opmerking:
If you have the other display compare the connectors and cable lenghts. Ralph
door
Voeg je antwoord toe
Bernie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 651
