Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Water damage - What to test?
Been given an iphone 6 to look at for water damage, but it has been left to sit for a couple of weeks before getting to me, so there is rust and some evidence of corrosion on the flex cable connections.
Is this worth even taking apart? I know first steps would be to clean everything with isopropyl. But what else can I do after that and it doesn't work?
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Water damage is always tricksy because you're not sure what the extent of the water damage could be. Check out this great answer by oldturkey03 here How do I clean corrosion after water damage? he gives some tips on how to deal with water damage.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Duane zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 3,726
