Ga door naar hoofdinhoud
Lenovo ThinkPad T500. Dit is een zakelijke laptop die in juli 2008 werd geïntroduceerd. Deze 15,4″ notebook kan geconfigureerd worden van een 2,26GHz Intel Core 2 Duo P8400-processor tot een high-end 2,8GHz Intel Core 2 Duo T9600-processor (of 3,06GHz Core 2 Extreme) en Intel geïntegreerde of ATI switchable graphics.
Why is my computer getting so warm?
After 30 minutes of use, the laptop is very warm on the bottom and is uncomfortable to have on my lap. What's going on?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
There could be several reasons your laptop is getting hot. First off, laptop is a bit of a misnomer--they get hot and are meant to be used on a desk. Secondly, this laptop is a good 7 years old at this point, when was the last time (if ever) it had a thorough cleaning done on it?
Start with the basics and clean it out, new thermal paste, etc. Then if you are still experiencing abnormal heat issues (ie, burning your flesh), then there are some other issues at play here. If it is heating up after 30 minutes, though, probably needs a good cleaning.
Was dit antwoord nuttig?
Score 3
Use your laptop on a Hard surface so the fans and case can dissipate the heat the right way. If you use it on your lap you have your body heat + the laptop heat, which will make it hotter.
http://gadgetwise.blogs.nytimes.com/2009...
Hi! You may have a problem with your fan. Try to clean your fan with a compressed air can.
If the problem persists, take a look at the Troubleshooting page to diagnose your exact problem.
Lenovo ThinkPad T500 Troubleshooting
its probably because u are not cleaning our laptop at all. or even trying to clean most of it.
1 Opmerking:
Does like opening the laptop and cleaning some dust with air blower and stuff help run the laptop smoother?
door
Voeg je antwoord toe
Nickie Gurney zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 7,198
