Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Deze 16 GB Oppo Find 7a werd uitgebracht in april 2014 en is de goedkopere versie van de Oppo Find 7. Om de Find 7a van de 7 te onderscheiden, verwijdert u het achterpaneel en de accu. Er zouden twee serienummerstickers moeten zijn waarop X9000 staat, op de plek waar de accu in de telefoon rust.
change lens back camera
How can i change the lens of the back camera of my oppo find 7a??
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Filteren op:
It isn't very hard. You can buy lens replacement on aliexpress or another Chinese site. To replace lens you have to follow these steps:
1. Take out back cover
2. Remove battery
3. Remove SD card
4. Remove all Phillips screws from back of the phone (some might be hidden under rubber caps - see other guides with photos .
5. Pry open the internal back chassis starting from a place near power button (credit card is a great tool for it. Don't use anything metal)
6. The lens is glued to the part you just pried open.
9. Detach the lens (well in fact it is a glass cover with UV filter) by applying some force from internal side of the back chassis to the glass - it should be quite easily pushed outside of the back chassis
10. The replacement lens should come with a glue ring.
11. Apply the glue ring to the side of the lens marked by white dot. Be careful to align it properly before applying. You don't want to make lens dirty, especially from the side facing internals of the phone.
12. Put the lens in the hole, glue down.
13. If required clean the lens from inside. You won't be able to do it later. Make sure there is no trace of glue, dirt, smudges or dust particles.
14. Put the back chassis in place. Press it until it clicks in place.
15. Reapply the screws
16. Insert SD card
17. Insert battery
18. Reattach back cover
Congrats, you just did great!
Was dit antwoord nuttig?
Voeg je antwoord toe
rudydellefave zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 1,708
