What do I do if my Kyocera Event keeps restarting?
Every time the phone is in use it will power down and return to the start up screen.
Is dit een goede vraag?
Soft Refresh
This resets your phone without resetting any of your data.
First, hold the power button. Then, tap “ok” to turn off the phone. Next, remove the battery from the phone for about 30 seconds. Finally, pop the battery back in and turn the phone on.
Clearing Application Cache
Clearing the Cache deletes unnecessary temporary data files that take up valuable space on your device. These temporary data files may cause performance issues if they take up too much space.
Go to settings on your phone. Next tap the “Apps” section, then “All.” They, tap the desired app, and tap “clear cache.” Repeat this for all apps, especially the ones that may take up more memory.
Low Storage
Most phones eventually run out of storage which causes many issues.
Uninstall any unused apps, don’t worry, you can reinstall them later if needed.
Next move any applications to the SD card, provided you have one. First go to “settings”, then tap on the “Apps” section. Tap on the desired app, and select “Move to SD card.”
Was dit antwoord nuttig?
PAY ATTENTION
QUESTION-What do I do if my Kyocera Event keeps restarting?
ANSWER- hold the POWER BOTTON AND PRESS THE DOWN VOLUME BOTTON for about 3 MINS and then this will RESET you phone PRESS clear cache.” SERVAL TIMES FOR THIS TO WORK.
I GRANTE THIS WILL WORK BECAUSE IT WORKED FOR MY PHONE
It worked om Dura Force Pro.
Did you lose anything?
This didn’t work for me at all. Any other suggestions or websites for flashing the phone it’self
It's going to the verizon load screen then stops, and resets again
It's most likely the memory capacity reaching it's limit. Activate developer options (instructions on internet) and go down to memory, which in my case is 3 GB clear any cache on any apps. This doesn't clear your apps it just clears the flash memory.
FIX!!!... replace the battery it is a lil work but this is the fix... I Have the Kyrocera Pro and it went into constant reboot. Ordered a new battery you need to get a micro screw driver kit and take the %#*@ thing apart and replace the battery it somrtimes has the problem of sending bad voltage / amps to the kyocera which makes it restart over and over Good Luck Worked for me!!!
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 109
Altijd: 17,327
8 opmerkingen
If u take battery out an put it back in an plug a charger to it the battery comes up an ehen u turn it on it restarts its self over an over
door David
Mind is a kYo c6725 an its not fixed yet I been at it for 45 MIN
door David
My Kyocera c6745 goes off an comes back on when I go to my dial pad
door kala barfoot
Just wait until the battery dies
door aquataocean
I'm having this problem too, but mine doesn't have a battery to take out, it's part of the phone, what should I try?
door sjshanks86
3 commentaren meer tonen
