Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De OnePlus One werd in het voorjaar van 2014 uitgebracht, is uitgerust met een 5,5"-scherm en draait op het op Android gebaseerde besturingssysteem CyanogenMod 12S. Model "ONE A0001."
Phone got wet touch screen problems
My OPO had a quick (1 second)drop in a toilet. It was in a protective case, inside of a leather holster. I wasn't wearing a belt and the holster slipped off of my pants. When I pulled it out and wiped it off with a paper towel, the screen was totally unresponsive. I was away from home and there was no rice to be found. I tried to shut it off but when I pushed the power button, I couldn't press shut down or restart on the display. (I later discovered that continually holding the power button shuts off the phone.) I put it in a bag of rice overnight and for the most part, it worked. Now, when I scroll the screen (like through my contacts) it's very touchy, opening the contact that my finger landed on to start the scroll over and over. I've tried adjusting the 'Touch & Hold Delay' but it makes no difference. Sometimes, it won't recognize when I try to make a selection near the bottom of the screen so I have to rotate my phone to landscape. But when I use the onscreen keyboard at the bottom (in portrait) everything works except when I press the 'a' key, it often pushes the shift key as well. Does this sound like a problem that replacing the screen would fix? It's irritating, but right now I can live with it.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Most people think of rice when their phone comes in contact with water. The truth is rice does not do much for a water damaged phone. The best thing to do when your phone comes in contact with water is to disassemble the phone and remove the battery as soon as possible. Then clean the motherboard and other parts with 90% or higher isopropyl alcohol and a small soft bristle brush, toothbrush works well. Doing this helps remove minerals left behind by water when it dries. If the minerals from the water are not cleaned from the motherboard and other parts then corrosion, or possible shorting may end up damaging the components inside the phone.
Cleaning with isopropyl alcohol may help fix your issues with the digitizer not functioning properly. As there may be some corrosion present on the digitizers cable end or its connection on the logic board leading to a poor connection.
If cleaning with isopropyl alcohol does not help you may need to replace the digitizer eventually.
Also there are many instructional videos on sites like YouTube that will show you how to clean your water damaged phone with isopropyl alcohol. Hope this helps and best of luck.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
frank manerchia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 27,285
