Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
Bought a 6plus to repair screen but now has vertical lines.
I purchased a 6 plus to do the screen repair and flip it. The guy said he cracked the screen trying to put it back on and I started it up and worked fine when it came. I took the screen off to test another 6 plus screen I had to see how the assembly was and now that I put the original back on it doesn't have display on just shows white screen with some vertical lines. Any thoughts?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Sounds like the screen that came with the phone is shot. You can purchase a new one here and use the guide here.
iPhone 6 Plus LCD and Digitizer Afbeelding
Product
$79.99
Was dit antwoord nuttig?
4 opmerkingen:
Really, the screen would just go out after being taken off and then plugged back in?
door
Check for bent pins on the connector. Does this screen on another phone?
door
On the connector on the mother board side or the ribbon cable for the lcd digitizer? I will check on another phone to see if it's the same.
door
On the ribbon cable for the digitizer
door
Voeg je antwoord toe
dcboy712 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 382
