Sony Bravia 32 inch LCD KLV-32EX400 display panel cost in India
Hi,
Can any one help me fixing vertical, Horizontal lines and ghost image(double image) on my Sony bravia 32 inch LCD TV. Is it possible to repair it instead of replacing the panel. The panel in India costs around 12500INR. Please help me resolving this issue.
Thanks in advance.
Regards,
Naga Suman
Is dit een goede vraag?
29 opmerkingen
Naga Suman, post an image of what your screen looks like. this could be as simple as bad capacitors on the power board, or a bad T-con board right up to as bad as a TAB failure on your panel.
door oldturkey03
My Sony 32bx350 lcd tv's picture jumpy.....flickering...the servicemen told me its panel has to change and its cost abt 12000.....I think the panel has no problem. May be some little issue in main board or t-con board. Anybody can answer what will be the problem.
door sudeeshck
I too face the same issue all of sudden while watching suddenly double images came, my 32 EX400 same model TV has the double image issue which we bought in 2010. When the service guy visited he said display gone we need to change the display and it costs around 13K with one year warranty. Don't know why such a big brand Sony has such type of issues without any repairing just replacing...
Regards,
Gauri
My complaint#37092766 from PUNE INDIA
door Gouri Savalekar
In normal models sony uses samsung panel or lg panel. The failure rate of samsung panels are very high, That is the problem. The problem is with its internal crystal leakage or with bonding. In some cases it is possible to repair, but it required bonding machines and same CAF
door THRIDEEP KUMAR
In my case the upper layer of LCD seems to be whitish and there is wrinkles all around the panel also.on the bottom portion a white patches is visible and it is also hiding the picture a lot. I mean if I say the LCD has two layers the inner most layer is showing the picture correct and the upper layer is becoming faulty. How do I rectify this problem.should I have to replace the whole panel or the upper layer can be changed. Vijay,Ranchi
door vijay bhagat
24 commentaren meer tonen
