Ga door naar hoofdinhoud
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Vragen Bekijk alle
Should I re-apply loctite on the screws after upgrading my hard drive?
Should I re-apply loctite on the MacBook Pro bottom shell screws after upgrading my hard drive? I have the unibody with non-user replaceable battery.
Also, is it bad to open the bottom shell once a month to make a hard drive swap? Are the screws and the threads in the case going to wear out?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I would never use loctite on a computer. You could find yourself unable to remove the screws to do repairs. It is unlikely the screws will wear out but if they did or you should lose one replacement sets are readily available at reasonable cost. Ralph
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
+ agreed
door
Voeg je antwoord toe
Michael zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,878
