Ga door naar hoofdinhoud
De Acer Iconia One 7 is een tablet die in april 2014 werd uitgebracht. De Iconia One 7 is een compact pakket vol mediaplezier. Met een display dat groter is dan bij een phablet en dat zowel helder als kleurrijk is, krijg je een snelle respons en urenlange batterijduur om door te kunnen gaan. We hebben ook ons Kids Center-platform toegevoegd met veel toffe dingen voor kinderen, die ouders kunnen beheren.
Acer Iconia One 7 Screen Digitizer Video Tutorial
Could you please make a Screen Digitizer replacement video Tutorial for Acer Iconia B1-730 ? is there any model that has similiar process of digitizer replacement and already published in your youtube channel ?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi There, I am looking for the exact same tutorial. Were you able to locate one?
Was dit antwoord nuttig?
Score 1
I haven't found one. So I tried myself the replacement seeing similar tutorials with great success. Now, the tablet is working again with a new digitizer, however I still have a problem with the screen calibration. The digitizer is working good, however when I point my finger on it, the command is recognized in a different position, some centimeters above from my finger position. Anybody knows how to fix it ?
5 opmerkingen:
Hi, Did you ever sort this - I am doing a repair and have the same issue! on two different digitizers!
door
Nop. Problem still remains.
door
I have decided that the digitizers sent are not 100% correct. They appear to fit perfectly but they do mask the edges of the lcd slightly. Tried a 3rd digitiser and still the same issue. I have a new tablet coming and will compare the digitiser measurments.
door
Looks like the only available digitizers are not 100% the same size, The side borders are too wide so obscure some of the lcd and the heights are a bit thick too. Has anyone replaced a digitizer with a ebay special and it work ok?
door
Hi Jon... the same happened here with my digitizer. The measures is not the same like the original one.
door
I want to repair my acer iconia tab 8 but i dont know where to found à new screen cam someone help m,e :( ?
I wanna ask on what button should I select to organize my apps?? Thank you
Voeg je antwoord toe
ricartengenheiro zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 2,485
