Ga door naar hoofdinhoud
Released in 2011, this phone is available on GSM networks with a 3.7-inch touchscreen, 1GHz processor, 3MP camera, Bluetooth, Wi-Fi, GPS and Memory card slot, additional camera. Model number: SGH-T679.
2 Vragen Bekijk alle
Why is is only one side of the audio playing
every time I plug up my headphones I can only hear the audio on the left side so I thought it was my headphones but when I tried my sisters and my brothers headphones I still couldn't hear any audio on the right side
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You may need to clean the headphone jack. It may have lint or dirt built up on the point that makes contact with the headphones plug. Which may result in a poor connection causing only one side of the headphones to work. Try blowing out the headphone jack with compressed air or clean the jack with 90% or above isopropyl alcohol and a q-tip or pipe cleaner or whatever small brush can fit in the jack. It could also be that the headphone jack is not making proper contact with the contacts on the logic board. You would have to open the phone to be able to see if this is the issue. If cleaning the jack doesn't fix the issue then the headphone jack may be faulty and needs replaced. There may also be a software or app issue causing the problem, which a hard reset may fix. Let me know if you figure it out.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
len kagamine zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 145
