Ga door naar hoofdinhoud
Een telefoon met snoer en bijbehorende draadloze telefoon, ontwikkeld door Uniden.
There is noise/static on the line
When I go to call someone i keep hearing static on the line.
Is dit een goede vraag?
Score 1
1 Opmerking
For troubleshooting, Uniden D1688 Troubleshooting.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Check for interference from appliances (microwave ovens, TV's etc.). or wireless devices (baby monitors, WiFi equipment, etc.). Move the handset or base away from the interference source.
If you use a telecoil hearing aid, turn on T-coil mode in the Handset Setup menu. T-coil mode shortens talk time, so keep your battery fully charged.
Check Troubleshooting page Uniden D1688 Troubleshooting Repair
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Randall the troubleshooting guide is just a placeholder (has nothing).
door
Het nuttigste antwoord
If all of your handsets have static then its likely your phone line has a problem.
You should call your phone service provider to check the lighting arrestors and your phone lines grounding. Often the arrestors wear-out and your grounding rod and/or power line ground connection is not good. In some cases the grounding is though your waterline (copper line). Corrosion can effect the effectiveness of the ground.
Score 1
Voeg je antwoord toe
Zachary zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 22
Altijd: 2,964
