Ga door naar hoofdinhoud
De Asus Zenbook UX31A is een laptop die in juni 2012 werd uitgebracht. Het is een lid van de Ultrabook-lijn van Asus. Hij is uitgerust met een 3e generatie Intel Core i7-processor en een full HD IPS-scherm.
ZIF Mainboard-Touchpad cable lock broken
Hello,
The cable lock/socket hinge on the motherboard of my Zenbook broke off after I misjudged it for one with a slide lock and pulled it out. Afterwards I also lost it.
Now obviously the zenbook has no connection to the touchpad.
Here's a picture of the connector without the hinge: http://i57.tinypic.com/2vxhs3s.jpg
How do I fix this? Can I replace the connector? Can I fix the connector? Could I maybe swap the connectors (i.e. put the working connector from the touchpad on the mainboard and then replace the touchpad)?
Its such an annoying mistake and I feel really stupid I hope you can help me.
best regards Alex
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Try using a hot glue gun. The glue is too thick and dries too fast to spread into the actual connection. I also doubt it'll melt any of the cable sheathing, but just in case, heat up a drop, wait a sec or two and see if you can mold it into the joint with your fingers.
Was dit antwoord nuttig?
Hello ledieu,
did you find a solution for your problem?
Same happened to me just know.
Would be great to hear from you!
No I haven't
But if you try the hotglue I'd like to know if and how well it works.
For me I have it half fixed with tape and folded paper to hold the cable in the socket
But sometimes the connection drops
Voeg je antwoord toe
ledieu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 1,621
