Ga door naar hoofdinhoud
XTouch CT-230141 tablet.
1 Vragen Bekijk alle
upgrading battery from 2800 mamp to 3200 mamp
is i can upgrade a battery with more power for my tab ?
Ex: 2800mamp to 3200 mamp ?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Mohammed Buhari sure you could if you can find one that fits your XTouch. Be aware of the scam with higher capacity batteries etc. Most of those are not any better than the standard batteries. You can try and search for a better battery based on the physical size of yours as well as the connector. Check reputable sellers only. Check this De mythe van batterijen met "hoge capaciteit" since it is still true today. Remember, higher capacity batteries also take longer to charge
Was dit antwoord nuttig?
Score 1
Now Why? How do you upgrade a Battery’s MAH
IS A BAD IDEA TO DO IT!
Voeg je antwoord toe
Mohammed Buhari zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 150
