Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
I've just got finish replacing my screen
I replaced the screen on my iPhone 5c and all I see is a black screen and white lines going down the left side of my screen.I can still turn my phone on and off but when I turn it off I don't see the "slide to power off" or the Apple logo when I turn it on. I just see white lines. Also, I looked at my digitizer and my LCD cable and they look completely fine. I also hear the snap when im connecting them to the logic board. So, I have no idea what can be wrong with it
Is dit een goede vraag?
Score -1
1 Opmerking
Can anyone help me or tell me what they think the problem could be.
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
kobe, something like that
can be caused by a bad digitizer connector
like this. Check the ends of the connector. The plastic of the connector has been compressed into the connector, causing it to flare out and preventing from making proper contact.
Was dit antwoord nuttig?
Score 1
It could be a faulty display order a new display and fit it and see it it works.
When you switch the phone on can you still call the phone and it rings?
Possibly the LCD flex ribbon connector is the problem, check if it's dirty or damaged. Or you'll have to buy a new replacement.
These guys are right---bad displays are really common. You'll have to rule that out first before looking for board damage which can also cause this.
Voeg je antwoord toe
kobe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 129
