Ga door naar hoofdinhoud
Reparatiehandleidingen en probleemoplossing voor de Acer Aspire V5, een serie laptops met Windows-besturingssysteem van Acer.
Screen Wont Turn on help please
When i turn on my laptop the light of the keypad turns on but my screen is all black? Need help please.
Is dit een goede vraag?
Score 9
5 opmerkingen
I have the same problem now. I know it's alive but no screen. I have my QuickBooks running and hate to force it turn off.
door
My screen won't turn on , but lights on the keypads work?
door
The light on the on/off button turns on for a bit but the screen and the rest of the camera don't react at all when I try to turn it on? Surely if the batteries were dead the light on the button wouldn't turn on?
door
Is Completely Black , Looks Like Internal Screen Damage
door
Thanx ifixit your information is very productive. ..I just fixed the problem with my acer v5..thanx again
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Dear All,
* Press Fn+F5 or Fn+F6 simultaneously while notebook is turn on
* if display switching not works just connect your laptop to external display and re-start (press and hold the power key until power LED goes off. after couple of seconds press power key again) and check any visuals on external display
* if you can see any visuals on External display, you should check the internal display and Flex cable and connector as well
  • Open the cover of RAM slots and remove RAMs safely, clean the RAM interfaces, reinstall RANs safely and try to boot normally
* onc of above step not works for you, its time for advanced level repair to check the GPU output and and CPU clocks and Bus (Board level repair)
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanx ifixit...Your information is very productive.. With your help i just fixed the problem with my acer v5..thanx again
door
Hi friend,
Kindly reset ur bios..otherwise properly fix RAM.
METHOD 1:
Step1: turnoff ur laptop
Step2:remove ur battery
Step3:hold on power button 30sec
Step4:after directly connect the charger trun on ur laptop its working .after connect battery.
METHOD 2:
First u identify ur RAM part of the ur laptop.
Just remove ur ram and clean tha pins smoothly.
After re insert the RAM check it ..working or not.
If u any doubt text me my number:+919524629460 whatsapp
Voeg je antwoord toe
Ana zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 12,699
