Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
1,8 GHz dual-core Intel Core i5 of dual-core 2,0 GHz i7 (Turbo Boost tot 2,8 GHz) met 3 MB gedeelde L3-cache
No Audio Input/Output Devices detected!
Hi All,
My Mac was functioning wonderful until, I upgraded to yosemite suddenly the audio input/output devices aren't detected! I have tried all the trouble shooting steps online NVRAM, PRAM to clean install of the software back to mountain lion and now running mavericks, but all in vain!
Took it to the authorized service centre they failed to diagnise my problem and detected fault on MLB (Main Logic Board) for which they are charging a bomb!
I would like to know if there is any work around to get the sound working! I read about external audio devices which doesn't require any drivers come in handy (Sabrent) should I settle for this? I am confused and frustrated with my MacBook Pro! Please HELP!
TIA
Is dit een goede vraag?
Score 3
2 opmerkingen
Just so its clear here your built-in microphone and speakers are not working, correct? or are you having problems with the audio output phono jack?
door Deel
i am suffering with the same problem, the same model, and also dont find any solution for it.
Any solution out there?
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Have you looked at these? USB audio input/output adapters
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
xroadsinc zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 37
Altijd: 3,438
