Ga door naar hoofdinhoud
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Vragen Bekijk alle
I like to know how to turn on my MacBook air without keyboard
hello I am very proud of this website I looked everywhere I have not found I like to know how to turn on my macbook air model A1370 mid 2011 without keyboard
Is dit een goede vraag?
Score 3
1 Opmerking
You are looking for the power pads on the A1370?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
men, use the power on pads. Bridging those two pads should power on your MBA unless there are other issues with it.
Was dit antwoord nuttig?
Score 8
1 Opmerking:
This was super helpful. Thank you ❤️
door
Hey men
What is probably the easiest way to do this, would really be just to remove the MacBook’s battery. If the battery isn’t present the power button becomes disabled because your power runs from the charging brick the MacBook came with. So if you connect the MagSafe connector, the Mac turns on instantly. If you disconnect it the MacBook kills because there is no power.
Hope this helps!!
Score 2
Voeg je antwoord toe
men zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 1,904
