Ga door naar hoofdinhoud
The Dell Inspiron 580 covers the basic computing needs. It may not provide the most advanced version of each feature, but the basics are available and provided for users.
12 Vragen Bekijk alle
How to fix the fan falling in the computer?
I need help to fix a dying fan.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hello Andrew,
Could you specify a bit more?
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Okay There is a wired noise and it is very very annoying.
door
Thank you, you can try to fix it (maybe not possible, evaluate it)
If you see its full of dirty, you can clean it with patience with a brush and put some drops of olive oil in the axis of the fan to run smoother and with no noise. IF this doesn't work you can allways buy a new one ;)
door
This is not for your specific model but it will be pretty much the same steps. Get a replacement and your golden.
Dell OptiPlex GX260 Main Fan Replacement
http://www.amazon.com/Dell-Inspiron-Stud...
Your actual DELL manual.
http://downloads.dell.com/Manuals/all-pr...
Score 1
5 opmerkingen:
Is it a clicking/ ticking noise?
door
No and no and no
door
Can you describe the noise? Most of the time those sounds you are hearing are your hard drive failing or about it is about to fail.
door
Look at what kind of hard drive you have (Seagate, Western Digital, Toshiba...)
Take a look at this once you find out your maker.
http://datacent.com/hard_drive_sounds.ph...
If you have these sounds then it's your hard drive.
door
It keeps changing but it isn't a clicking/ ticking noise.
door
Voeg je antwoord toe
Andrew Chukin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 916
