Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
Error bug after replacing screen
Okay, so i just replaced the iPhone 5c screen after watching a guide, when i boot up the iPhone it worked for about 3-4 hours then the touch screen went out but there was still display then rebooted the apple logo diplayed with a paragraph of numbers and words about the "[NAND] _flashmediaandkeepout:601 physical nana block offset 1" what does this mean? how can i fix it? Thank you! Here is a picture.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Reset, hold both home and power buttons for about 10 seconds until the iPhone restarts itself. If still problem, turn iPhone OFF and open up iPhone again and carefully reconnect the front screen flex connectors to the logic board perfectly. If there is trouble turning iPhone OFF, hold home and power buttons for 2-3 seconds until it turns OFF, then release the buttons.
Was dit antwoord nuttig?
1 Opmerking:
I tried the reset the lines went away but the booting error persists the code continues to show again and continues rebooting continuously
door
looks like this is not good
I've the same problem !! what's the solution. Should I open the iPhone and what to do ?
Voeg je antwoord toe
David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 311
