Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Vraag afgerond
Error 4013, a part is free inside my phone
Hello, I've got faulty Iphone 4S (error 4013). Battery has been changed but when I opened my Iphone, I found a part free inside...very little, about 3x3mm
Does anyone can tell me where this part should be placed ?
Here is the pictures (not very good quality, sorry)
http://i.imgur.com/NhSIilY.jpg
http://i.imgur.com/JL00RKq.jpg
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Hi.
The left over part is the small black ground clip on the upper screw of the battery connector.
The picture show you where to put it :)
You can see it on step 5 in the "iPhone 4S Battery Replacement"-guide
Just slide it underneath the batteryclip
For the error 4013: Put the left over part back in right place ;)
Check the dock connector. Is it connected to the logic board correct?
If all seems fine, you could try to restore thru DFU-mode. Check this guide: http://thebigboss.org/guides-iphone-ipod...
Was dit antwoord nuttig?
Score 2
Hello,
See here, step 2 : https://www.ifixit.com/Guide/iPhone+4S+B... part 5'''
"Take notice of the position of the small black ground clip on the upper screw of the battery connector. This clip is attached only by the upper screw. When reinstalling, it must be aligned so the gold contact point will press against the back cover."
This small part has not been put back in place when the battery has been replaced
HTH
Thank you Alex and Georges, I was almost sure this part was came from this place.
Unfortunately error 4013 is still there. I tried to disconnect almost everything (display, digitizer etc...) but no luck, I think my Iphone is down. C'est la vie.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 945
