Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Vraag afgerond
Low signal and microphone after dropped to water
Hi,
I have an Iphone 5s. I accidentally dropped it in water in my dream( don't ask how) and it stayed in water for at least a few hours(maximum 8). Fortunately it was in an Otterbox Defender, which saved it from an immediate death. Everything works perfect except from two things: there is low signal( 0-2 in my town(in bigger cities it raises to maximum) and the mic during calls is not working( with a microphone connected as well). 2 men tried to repair it, but non of them succeeded. The first one was an idiot but the second one is a respected and good technician. I researched a lot, and I found that replacing the "lightning connector& headphone assembly" maybe helps. I asked the second technician whether he had replaced this part or not and he said yes and he said only a logic board replacement could help. I don't believe him. The logic board is too far from the speaker/microphone where it got wet. And, there is two things not working on the "lightning connector& headphone assembly". Do you guys think it worth buying one and replacing the old one? I
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
In my opinion, I would replace the lightning connector and headphone assembly. The logic board does not have anything to do with the problem.
Here is the link to the repair guide - iPhone 5s Lightning Connector Replacement
It should only take you 25-45 minutes to fix and about $30.
Let me know if this helps.
Was dit antwoord nuttig?
Thank you very much!
Knowing this, I will give it a try. I am from Hungary, where IPhone parts are really expensive, but I found a used and working lightning connector and microphone assembly for 4000 Huf( <20$). It's worth to try I think. I once replaced my battery with no problem, and I have a few tools as well so I can do it. The spare part maybe arrives on Wednesday so I will reply soon.
Keep your fingers crossed for me!
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 92
