Ga door naar hoofdinhoud
De Raspberry Pi Model B is een single-board computer ter grootte van een creditcard die in februari 2012 werd uitgebracht door de Raspberry Pi Foundation om het onderwijs in informatica te stimuleren. De oorspronkelijke Model B werd in 2014 vervangen door het verbeterde Model B+.
no green light showing
have red light but no green light
Is dit een goede vraag?
Score 10
Voeg een opmerking toe
10 Antwoorden
Het nuttigste antwoord
There are 4 LEDs, on the pi, two for the Ethernet port, and two separate ones. I assume you mean the separate ones, as these indicate power.
Red is for power on. It being constantly on is nothing but an indicator that you raspberry pi is getting power. Its connected directly to the power source, and does not indicate any code running on the pi.
Green is for SD card. It being off indicates that your SD card is not properly set up to boot the PI. follow the instructions for NOOBS to properly prepare your pi.
Was dit antwoord nuttig?
Score 10
I believe the green light signals network activity. Plug it into a network and send it some data. See if the green light blinks.
Score 3
From what I can tell, the red light is normal. I also don't own one but from online pictures it's red light...
Score 2
The green light next to the red light as a data activity light. If this light does not start flashing at power on if the SD card is prepared correctly , once system loads the light stops flashing and waits for activity.
Score 1
wrong case?
https://www.raspberrypi.org/forums/viewt...
Score 1
== how to add too fans. ==
Score 1
Your SD card may be dirty; try cleaning it with your thumb. It didn’t work for me, but it will probably work for you.
Score 1
if the raspi works, just don’t bother about the lights.
Red light will be on if there is +5v suppleid ok, and flash if there is less than ideal voltage to the rPi. If you have just the red light and no green light, verify your SD card first. If that checks out ok, then you just might have either a blown power diode or a bad regulator. you can replace the diode, but the regulator cannot be replaced unless you take one off of another Pi. I hear they are either programmed or serialized, so a new part won’t cut it.
in my case both lits are glown contunusilly
Voeg je antwoord toe
film49 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 43
Altijd: 16,169
