Ga door naar hoofdinhoud
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
20 Vragen Bekijk alle
Buttons on Nintendo 2DS get stuck?
The trigger buttons on my Nintendo 2DS are stuck in the down position and nothing I do will fix them. How can I get into the device to fix this?
Is dit een goede vraag?
Score 1
1 Opmerking
I am confused by what you are saying. If they are stuck in the down position, they would both be energized all the time. Please tell us more about what this is doing that it should not and what it is not doing that it should.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The trigger buttons are supported by springs, so it's possible that those have broken or somehow come out. Its also possible that something sticky might have gotten under the button and is holding it down. This Guide links to some repair documents that you might find useful.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Fina Beauchamp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 4,074
