Ga door naar hoofdinhoud
Repair information on tablets manufactured by Dell.
105 Vragen Bekijk alle
Screen is cracked but now only half of screen works
So, only in a part is there a crack, but I have problems with the right half of the screen. The left side moves things when I touch it as it should do, but when i go to the left side, nothing. it doesnt work. It looks normal and everything. the screen is pretty clear, but i dont know what to do.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Haley, you did not tell us which tablet you have. From your description of the symptoms, it sounds like your digitizer has failed because of the crack. It does not matter what side is cracked, it will ruin the continuity of the circuitry in the digitizer. Replace it to repair the function.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
It is a 8 inch Dell venue 8 3830 tablet
door
Voeg je antwoord toe
Haley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,007
