Err code on display . Camera stop responding.
My D80 shows err code. Try to change lens. Try change f stops. Still the same.
Is dit een goede vraag?
Usually, on a Nikon D80 with an "err" message that won't go away, the Aperture Control Unit must be repaired or replaced. There is a small switch contact held on by a small plastic rivet in the Aperture Control Unit that tells the electronics module in the camera what phase the camera is in during its cocking cycle. When that small plastic rivet breaks, the camera can't determine where it is in the cycle and just stops and displays the "err" message.
There are 2 ways of fixing the problem, replacing the part with the same weak plastic-riveted switch contact or taking the Aperture Control Unit apart and replacing the plastic rivet with a small steel screw which can't break again. I've been using the second method for many years now and haven't had a single body experience the same problem again.
Bob Kilbourn
Was dit antwoord nuttig?
Hey Bob, where did you get this small screw from and what size of screw did you get? Thanks
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 22
Altijd: 3,356
1 Opmerking
my cam had the same issue got it repaired at very less price at mata electronics. contact them at mataelectronics@Gmail.com
door Bitu Kotai Deel
