Ga door naar hoofdinhoud
The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
20 Vragen Bekijk alle
How to Fix the Buttons on an original DS?
I replaced the shell on my ds system, All the buttons worked fine before but now most of the buttons are responsive! I've tried reopening it and fiddling with the rubber under them but to no avail! Any Help is greatly appreciated.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
you wrote "the buttons are responive" - did you mean unresponsive?
did you use an original nintendo case or one of those "original nintendo" cases from ebay ?
the problem could be to much pressure on one or more buttons, that way they act like they are always pressed and that way no button would work.
i would start the ds with the open shell and see if the buttons work or not
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Jared zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,794
