Ga door naar hoofdinhoud
Repair and disassembly guides for Kenmore Microwaves.
182 Vragen Bekijk alle
Vraag afgerond
Why is the microwave only heating when the plate spins?
we had our microwave for 8 months then one day it just stopped heating. The problem is when the plate moves it heats,when it doesn't it doesn't heat. where can we fix this.
Is dit een goede vraag?
1 Opmerking
I have the same problem & would like to repair. My Model is Kenmore 911.41485 or 911.41489. It is a built in micro with oven below. Not sure which model is for which.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. But your machine should still be covered under the manufacturer warranty.
What's your model number?
Was dit antwoord nuttig?
Score 1
I have the same problem & would like to repair. My Model is Kenmore 911.41485 or 911.41489. It is a built in micro with oven below. Not sure which model is for which. Can you share if this is possible & if so where I can get parts & how to do the repair? Thank you, Nikki
1 Opmerking:
Which model do you have?
Kenmore Microwave Model 911.41489890
Kenmore Oven/Microwave Combo Model 911.41489991
Kenmore Oven/Microwave Combo Model 911.41489992
Kenmore Oven/Microwave Combo Model 911.41489993
Kenmore Oven/Microwave Combo Model 911.41489994
Kenmore Oven/Microwave Combo Model 911.41489995
Kenmore Oven/Microwave Combo Model 911.41489996
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 203
