Ga door naar hoofdinhoud
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
My samsung s2 is not turning on only logo keeps flashing
My samsung s2 got dead n is not turning on after charging only logo keeps flashing
Is dit een goede vraag?
Score 5
1 Opmerking
my samsung s2 is not turning on
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Have you tried doing a hard reset to restore the phone back to factory settings?
The procedure does and will delete all files and downloads that are on your phone.
How to do a factory reset:
1) Turn the phone off. If you can't, remove and reinstall the battery
2) With the phone still turned off, hold down the Power button+Volume up+Menu buttons at the same time for about 10 seconds.
3) Scroll down and select 'Wipe Data/Factory Reset'.
4) Select 'Yes – Delete All User Data'.
5) Select 'Reboot System Now'.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
this method is not working to reset my samsung gallaxy s2.
there any other way using hardware support
door
Voeg je antwoord toe
Noureen Farooq zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 2,630
