Ga door naar hoofdinhoud
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 Vragen Bekijk alle
Vraag afgerond
Temp gauge,fuel gauge and turn signal dead?
Hi there. My temp gauge, fuel gauge and turn signals went dead all at the sime time. No fuses out and no visible burnt places on the wires and at the back of the cluster. Please help?
Is dit een goede vraag?
Score 1
1 Opmerking
And it is a 1982 Model and is still running fine.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hello, double check your fuses. They can have cracks that are not visible to the eye. Consider replacing the fuse the goes to the cluster; it's a cheap thing to help rule it out.
Then check the bunch of ground wires all connected together behind the cluster. Make sure it's properly tightened down.
Let me know if you have any follow up questions. You can ask here or email me, my address is in my profile.
Was dit antwoord nuttig?
Score 5
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,665
