Ga door naar hoofdinhoud
De Galaxy Mega werd uitgebracht in juni 2013 en is een 6,3" smartphone met een 720p-scherm, een dual-core processor en een 8 MP camera.
Samsung Mega Black Screen
I recently installed my replacement LCD digitizer for my Samsung Mega. Upon installing it the first time, the screen came on and I could see everything but would not respond to touch. I removed the back and the flex cables and reconnected them, now when I turn the phone on the screen is black but I can hear the phone turning on. Could you possibly tell me what may be wrong?
Is dit een goede vraag?
Score 2
1 Opmerking
Thank you for the advice, I will contact the person I purchased it form.
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi Brittany
Its possible the connector is not seated all the way and is causing your issue, Check that first.
If that does not solve your problem, its possible that screen has accidentally been damaged. I would test the device with another known working screen, if it works, then yeah the display is bad. If it does not work and its a known working display your testing it with. Then its the motherboard of the device that is not outputting a display and not the screen itself.
But like I said, its possible the new screen went bad. They can be easily damaged during the install process. Also by bending one of the cables to much could have caused damage.
Hope this helps in solving your issue.
V/R
Josh.O
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I agree with Josh This has helped me in the past.
door
Voeg je antwoord toe
Brittany zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 4,276
