Ga door naar hoofdinhoud
An aviation themed analog luxury watch from Breitling.
2 Vragen Bekijk alle
removing the bezel safely
How you you remove the bezel of a Breitling Navitimer Safely?
I heard there are screws holding the bezel down. hoo do i find these screws?
the gap between the bezel and case can barely fit a piece of paper. i can't get a knife in there. i plan to use a razor blade and see what happens.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Again I repeat don't try to use any blade as it could be held be three screws inside if its a later Navitimer.
Whereas the earlier 806 model can be lifted from outside with a proper Watchmakers blade.
Kind Regards,
Tony
Tony Arnold {Director}
arny@helios-electronics.com
Was dit antwoord nuttig?
Score 1
It depends on the model number etc
kind Regards
Tony
Don't use a razor blade, the edge could break and send shards into sensitive tissues, like your eyes. Yikes!
A watchmaker's tool or iFixit's Jimmy tool would be better.
Jimmy Afbeelding
Product
Jimmy
$7.95
Time problem
Voeg je antwoord toe
han zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 43
Altijd: 2,396
