Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1510 Vragen Bekijk alle
home button cable of iPhone 6 and plus is the common?
Hi, dear Ifixit technicist. I found a strange case this morning. One website showed the iPhone 6 replacement home button flex can also be used for iPhone 6 plus. Is it real?
the sizes are different between iPhone 6 and plus, their home butthon can be common to use? It is really strange. Have a look,
http://www.hytparts.com/005154-oem-repla...
Not only this parts, there is another parts as same as it about home button cables.
Is dit een goede vraag?
Voeg een opmerking toe
8 Antwoorden
Gekozen oplossing
This is crap information. iPhone 6 home button cannot be replaced. You lose Touch ID immediately and the phone bricks when trying to reinstall iOS.
Was dit antwoord nuttig?
Score 5
2 opmerkingen:
So what you lose Touch ID if you’re replacing it then it wouldn’t work either way but at least you get functionality. And I’ve never seen a “brick” when updated due to the homebutton. Source- 5 years experience in phone repair
door
Look at the answer, five years ago.
door
The iPhone home button can be replaced, but will lose Touch ID after replacement whether it's iPhone 6 or iPhone 6 Plus. If you do not need the Touch ID any more, the iPhone 6 home button can be used on iPhone 6 plus.
Score 2
8 opmerkingen:
how many times do i have to tell you guys? don't do this if you have iphone 6/6 plus, this will brick your phone completely!!
door
So what is a person supposed to do if they damaged the home button? Get a new phone?
door
Yes, Tim, or don't update/reinstall iOS and say goodbye to Touch ID.
door
That's stupidity. Way to go, Apple. Not everyone puts their entire lives on a freaking cell phone, and couldn't care less about its security. If you're putting your identity onto something you carry in your pocket, you kinda have no right to whine about security. I don't even use the Touch ID nonsense, nor a passcode lock. Having to buy a new $900 phone when a $5 part breaks is an epic fail. I'm seriously considering just cancelling my cell coverage and going to a landline. I don't know why cell service for smartphones still costs an arm and a leg.
door
There is a thing called warranty, and Apple can fix the phone by just replacing the display, not the entire phone, at a price of about $130. (still not $5 but better than $900)
door
3 commentaren meer tonen
Home button for iPhone 6 suitable for iPhone 6 Plus
Of course the fingerprint will not work, clicking Yes will work fine.
also home button for the iPhone 6S suitable for the iPhone 6S Plus, only clik.
If you switch between iPhone 6 and iPhone 6s clicking will not work
Score 2
1 Opmerking:
So its ok if i put a iPhone 6 plus button in a iPhone 6 right? I will just loose touch id
door
You got a lot of poor answers here. And some just unnecessarily blunt. But judging by your questions wording I think you probably meant the home button flex cable? You refer to Phone size...
The plain answer is no.
The iPhone 6 and iPhone 6 Plus home button flex cables are of different length and so the cable for the 6 cannot be used on a 6 plus. Other than having extra cable folded inside your 6 I don’t see any reason that the cable for the 6 plus cannot be used. This part itself does not affect the functionality of the touch ID.
As for the home button itself. What they say is true. Although the button and it’s assembly can be interchanged between these devices, once replaced you will lose all functionality of Touch ID. I don’t know about this bricking problem after updating. I’ve never run into it and I do this replacement all the time.
Score 1
4 opmerkingen:
Error 53 bricked your phone after non OEM parts were installed on the device. This was Purposely done bia software by apple to discourage 3rd party repairs. It was remedied on a subsequent update. And Tom Chai is a dickhead so yea
door
finally a answer that is useful thank yours iPhone6 plus button works for iphone 6 but iPhone 6 cable does not work for iPhone 6plus?
door
They are different parts. They cost two bucks so buy the correct one.
door
does you mean the iphone 6 or plus Home Button Assembly Replacement, here is the guide iPhone 6 Plus Vervanging van de thuisknopmodule
2 opmerkingen:
Don't do it. It simply breaks the phone.
door
ATTENTION
It is perfectly safe to change your home button in 2017 and later.Apple patched the issue that would brick your iphone if you tried to update after changing your home button.Error 53 has been fixed over a year now so why no one has spoken up on this post is beyond me.
door
Just a thought; could the button be replaced and if and when it is necessary to update the software just open the phone, unplug the button, update and put the phone back together.
could you please provide relevant information according to question ... many thanks
The home buttons are interchangeable between Iphone 6 and 6 plus, but touch ID will only work with the button that comes with the phone. If it's replaced with another OEM button, Apple can reprogram the button for touch ID. There will be no phone bricking if you replace the home button. I have done about 500 of these just this year alone.
Voeg je antwoord toe
vian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 7,309
