Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Beschikbaar vanaf september 2011. Scherm - 800 x 1280 pixels, 9,4 inch. Chipset - 1GHz Nvidia Tegra. 5MP camera achteraan. Android-besturingssysteem, v3.1 (Honeycomb), upgradebaar naar v4.0.3 (Ice Cream Sandwich)
WIFI does not work
Hi,
I can't connect to the wifi at home, it detects the signal but it does not connect to it. It thought it was my wifi's home, but at work it happens the same. I also went to another person's house and the wifi does not work.
I put the password again, disconnect and connect the wifi, but nothing happened.
Is dit een goede vraag?
1 Opmerking
polharder, has it ever worked for you? Did you change anything in your settings lately
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Try going to an open WiFi location (an AP without any security password). See if it can connect to it (altering your AP settings; going to McDonalds or Starbucks Coffee house etc...)
If it does work then you'll need to check the case of the password as upper & lower case are different here (even unicode characters). Also make sure the password is not overly long as some devices can't parse the key longer that 10 digits/characters.
Next check what security option you are using on the AP and make sure your device can do it. As an example some older devices can't to WPA 2.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
polharder zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 48
Altijd: 610
