Ga door naar hoofdinhoud
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Vragen Bekijk alle
black display screen after reassemble back iPhone 4
I replaced the power button cable and reassembled the phone. But now i only get a black screen. I hear a ding sound after plugging in the charger so I know the battery is charging. I can also connect the phone to my computer and have it be detected by iTunes. I took the phone apart and rechecked all the connections, and still nothing. Any idea what could be wrong
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Try reseating the LCD ribbon, because with everything else it sounds like the hardware is working fine. The issue is not getting the screen to wake up. Have you tried a hard reset while it put back to together.... its when you press the power & the home button at the same time for 20 seconds while it is plugged into a wall outlet for charging not a computer.
Was dit antwoord nuttig?
2 opmerkingen:
Thank you. The hard reset solved the problem.
door
Glad i could Help :0)
door
Voeg je antwoord toe
Cindy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 110
