Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
Screen not responding properly to touch
My screen was not responding to touch as it should (i.e. either no reaction at all in certain spots and otherwise jumping around when touched).
I replaced the screen as advised and at first it was much better as only one small spot on the screen was unresponsive and there was no jumping around. However, after 1-2 weeks it is now worse than it originally was. When the screen is touched it jumps almost every time (i.e. if I click on a message it acts as if I swiped it to delete or if I touch an email it won't open and the screen will jump up and down).
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Make sure when you replace the screen that no dust or debri gets in the enclosure and that it is sealed properly...also the ribbons connecting the lcd to board may also be faulty. you can try reseating the screen again and then test or if you are still under the warranty for the part used you can see about getting it exchanged.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Unfortunately, the phone is not under warranty. If it is the lcd ribbon is there anything I could do?
door
All the signs of a faulty screen and its deteriorating through time..
Time for another screen remember cheap is not always better
1 Opmerking:
Thanks though I'm not sure if it would be related to actual screen as I've had this problem within two weeks of installing two separate new screens. Also the screens I buy aren't cheap, they are sold by iCracked on Amazon are are generally rated high. I have bought from them for other phones and never had an issue before.
What do you think?
door
Voeg je antwoord toe
Yonah Stern zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 5,705
