Ga door naar hoofdinhoud
De Sony Xperia Z3 is een Android-smartphone uit 2014 die bekend staat om zijn lange batterijduur en duurzaamheid.
Replacing the nylon corners?
Is it possible to replace the nylon corners on the Sony Xperia Z3? I've cracked mine.
Thanks a lot
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Update for people that come here looking for a guide how to replace it.
The corners CAN be replaced. You can found it on ebay just searching "Sony xperia z3 corners" They are attached by presure clip to the main frame, you need to remove all the rest parts of the old one and clip the new one. Originally it goes thru a side, but you can put it by presure. Some chinese sell a model with glue to make it easier. BUT I don't believe that will last long.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
how to remove the xperia Z5 Premium nylon corners?
door
You can pull off with common tools for cellulars, and you need buy middle housing on ebay and change the broken part. Saludos desde México
I am afraid it's impossible. First reason, It's a part of the whole midframe. Second reason, there is no the replacement to buy.
So if you want to repair, you may need to replace the midframe, it's complicated and the waterproof can't be ensured any more.
Score -1
Voeg je antwoord toe
Emil Rune zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 4,207
