Ga door naar hoofdinhoud
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
81 Vragen Bekijk alle
Dodge ram 1500 2007 brake light and turn signals not working
I have a Dodge ram 1500 2007 yesterday my brakelights and turn signal stopped working I have changed the bulbs checked the fuses the tail lights work also the third llight is working front turn signals blinking fast.
Is dit een goede vraag?
Score 11
11 opmerkingen
I have the same Proverbs somebody tell me how to fix
door
I have 2002 Ram 1500 Sport my tail light work but my brake light doesn't how do I repair that
door
Had my truck worked on and now my brake lights and turn signals don't work
door
had my truck worked on now the brake lights and turn signals don't work
door
Anyone out there know what is going on with mytruck?
door
6 commentaren meer tonen
Voeg een opmerking toe
11 Antwoorden
Het nuttigste antwoord
There's most likely a short in the wiring at the rear of the vehicle. Trace the wiring on both sides from the bulbs towards the cab. It's likely very near the bulbs. There'll be a damaged wire most likely that's shorted to the body of the truck. A quick way of narrowing down the area is to put something on the brake pedal to turn the brake lights on and then shake the wiring harnesses. See which one causes the light to flash on. That'll be the culprit
Was dit antwoord nuttig?
Score 1
Had this problem still don't know how to fix it! But, what I ended up doing is transferring the tail lights to the trailer connector. This was over 7 years ago and it's still hooked up that way. If you figure out another way please let me know!
Joe
Score 1
3 opmerkingen:
I have the same thing. I have power at my trailer connector, but no blinkers or brake ...how do I wire the trailer connectir into the blinkers?
door
Just dealt with this today. I replaced the Brake Light Switch but, when I went to shift the truck out of park,I was unable to change gears but my steering wheel would not like. After spazing out and rechecking my work, I discovered that the little black lever,if switched in the wrong direction,it will lock up the gears and disable the steering lock. I have yet to see ANY mention of this on any forums and most people are not aware from what I'm now learning from a mechanic friend of mine. Makes you wonder how many "ghetto"mechanics activate that in order to charge someone more money for bs repairs....
door
Take a test light and check the fuse box check the turn signal fuses I've been told it blown that part of the box and has to be replaced to fix that issue
door
I had to re-flash my pcm, $176.00 for me. Good Luck.
Score 1
1 Opmerking:
Are you serious! That's crazy to have to do that to fix a simple light circuit. I'll never buy another Dodge again as long as I live.
Joe
door
I’ve had the same problem, 4 or 5 times at this point. Every time I have my mechanic plug in his tool into the OBDII port. I think he just clears the codes that come up and they work again. From what I understand, they made these trucks to where fuses don’t protect most of these circuits. Instead, they made the computer in charge of the fuses job, shutting off the circuit when it detects a problem. I’ve also read elsewhere that replacing the TIPM would fix this, but that’s an expensive fix. Anyone that knows anymore please help, I’m tired of it being Friday night and no place is open so then I don’t have lights for the weekend. This effectively disabled my truck!
Score 1
3 opmerkingen:
I just bought my aunt’s 2003 Dodge ram 1500 and they replaced the whole right tail light and the brake light works, but the turn signal and back up light does not and I have a message on the dash that says lamp out. I check the wiring. I hope this works because some times when I hit a bump the message will go out until I want to use the blinker again.
door
I had that problem as well I hit some bumps on a rough road it made my bulbs loose I changed them and they worked
door
I got a 2002 dodge ram sport and can't get reardriver side turn signal to work replaced all the bulbs the whe circuit in the assembly and still throws a bulb or lamp out butifipushbteak peddle in and turn on signal it works the head light wont turn on at the same time onecome on the other one shuts off when I hithighs and lows any guesses or answers
door
Hi @fed78837,
Did you check if the relevant fuse (26?) in the passenger compartment fuse block is OK, you didn't say.
I thinks that it is 26 but I'm not sure - check the fuse layout diagram in the lid.
Score 1
If your brake lights and turn signals are not working but the third brake light is working I would go with Nope's answer and check the wiring for a broken/bad wire.
I was going to say check the brake switch but since the third light is working there is nothing wrong with the switch.
I will stick with a broken wire more than likely under the bed at the very back. This is where I have always found the wires to be broken.
2 opmerkingen:
No brake lights ,turn signals wipers, or gauges working any ideas anymore
door
This is a rant, between my brother, myself, and a couple of sons there are more 2500,3500 Cummins powered rams than drivers...with more wiring issues Fuse panel Failure...and we worked it from one end to the other....but if u switch out said problematic box with one from a functioning same year (same plugs on bottom) is the winner, but not end of the road older years just need patience and schematic....The &&^&^$^ problem is where can I get 20 of them....Best news is my 2016 is now showing the same tendency....
door
Bad bulb. After you replace it you got to clear the codes on the control module.
Had the same issue I am a mechanic TIPM issue need to replace a total integrated power module my truck is working fine now
2 opmerkingen:
Thanks can you explain to me what the TIPM module is And how much it would cost if you don’t mind
door
And where is it located
door
I had the same issues. Checked the bulbs they looked good no breaks or burn spots nothing. checked the fuses and the wiring couldn't find an issue. decided to just go ahead and change the bulbs anyway and luckily that fixed it.
1 Opmerking:
Ok thank you sir
door
I had the same issue in my 07 1500. What finally fixed mine was reflashing my truck. I asked the local dealer to do it and they wanted to do a bunch of diagno$tic$. I remembered that I have a Bullydog GT tuner and used that to reflash my truck. If that had not worked I was getting ready to change the TIPM. I fought this for 6 months B4 the fix. Hope this helps.
Take a test light also and check your fuses under the hood I have this problem as well I have no turn signals no.brake light and no hazards I was told that I'd have to replace the entire fuse box cause it burnt that part of the board that controls that part
Voeg je antwoord toe
richwash1958 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 101
Afgelopen 30 dagen: 448
Altijd: 51,917
