Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
How to fix low VRAM?
Hi everybody,
Many thanks to Machead3 for your answer ! Well, you're right, the Macbook Core 2 Duo Model A1211 is built with 128 Mo of VRAM.
But as I said, the graphic chipset has been replaced after the overheating, but now, the bad thing is that I have just 5 Mo of VRAM instead of 128 Mo.
Is the VRAM comes from graphic chipset or from memory (RAM) modules ? Or perhaps from another component on the logic board ?
Many, many thanks to all the community for all answer about it.
Kind regards from France
Yves
PS: I'm sorry if I make any mistake... I'm a newbie for posting on the site.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Without knowing what GPU/VGC you put in the box I can't answer your question exactly. Generally however "shared VRAM'' is a more recent development and most likely not to be a part of your machine.
The VRAM is either on the card, or when not on the card comes from the machines RAM, only since about 08 has there been both/or switching of VRAM possible.
If this answer is acceptable please remember to return and mark it.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
yjusserand zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 679
