Ga door naar hoofdinhoud
Daisy Model 10 Carbine luchtbuks met 400 schoten en herhalend BB-mechanisme. Maximale snelheid: 350 FPS (106,7 m/s). Maximale schietafstand: 195 yards (178 meter). Spanmechanisme met hefboom. .177 kaliber BB's. Onderdeelnr. 300664-000
Why is my trigger not firing?
My trigger is loose and will not fire when I squeeze it.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If your BB gun is not firing it can mean one or a combination of five things: 1) Too many BB's in the loaded in the gun 2) Safety still might be on (easy fix simply push the little black button above the trigger until you see a red line on the pushed out portion of the button, then safety is off) 3) The BB's you are using could be damaged or dirty thus causing blockage at the firing chamber 4) BB's are not aligned in firing mechanism 5) Broken Trigger Most of these things can fixed easily while others especially a broken firing trigger might take a little more work to deal with. Refer below to the troubleshooting and repair guide to help walk you through correcting this issue
Daisy Model 10 Carbine Troubleshooting
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Trelawney Bullis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 26
Altijd: 14,688
