Ga door naar hoofdinhoud
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 Vragen Bekijk alle
What screwdriver should I use?
Hello there, I will be taking apart my 3DS ( Wifi card problems ) and I've been doing some research and it seems that the #00 Screwdriver which people recommend MIGHT strip the screws. Is this true? and if it is true what screwdriver should I use?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Alex, any screwdriver "MIGHT strip the screws". That is where the importance of good tools comes in. I prefer to use quality tools only, and invested in a set from here. The chances are slim to strip screws with the right set of tools.
Was dit antwoord nuttig?
Score 2
I used the smallest phillips screwdriver I had, and it worked fine but you have to press down firmly on them to make sure they grip tight enough without stripping.
Score 2
if it they arent coming dont force them. Apply a drop and i mean a tiny drop of oil (wd-40, pb blaster, trumpet oil, car oil, whatever). you need to let the drop of oil work in there for 20 seconds or so and try again. it is best to work the screw in and out meaning tighten and loosen it to get it free and even after its free you might have to tighten and loosen to work that oil in there. It will come out like this with patience
Score 1
Voeg je antwoord toe
Alex zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 534
