Ga door naar hoofdinhoud
1,7 GHz dual-core Intel-processor (Turbo Boost tot 2,6 GHz) met 3 MB gedeelde L3-cache
Power on pads for Mid 2012 MacBook Air 11" A1465
I found information for a 2010, 2011, and 2013 macbook air but I can't for the life of me locate the power pads for the mid 2012 macbook air 11". Here are photos and I hope a kind soul would be able to assist me.
I've only tried the flat head screwdriver method at this point but realized it wasn't a solder point. Yes, I'm an idiot =P
Afbeelding
Here's a photo of the board and I just marked locations where I think it might be located based on what I've read.
Afbeelding
I figure if powers on then I will replace the keyboard but if it doesnt then it would also involve the logicboard in which case I wouldn't bother fixing it.
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Asahi, here you go. Do not bridge any of the other contacts you marked.
Afbeelding
Was dit antwoord nuttig?
Score 5
5 opmerkingen:
OMG!!! This worked!! Thanks oldturkey03 =) I'm sure this will be useful for all the other 2012 MBA 11"with the same issues. Thank you thank you thank you!
door
you are welcome;-)
door
thx for photo, start my air after died power key button
door
You are FANTASTIC! do you know where the serial number for this board might be?
door
Diego V not sure what you mean by serial number
door
See this Answer - your case is similar. Use care shorting random pads on the logic board, you can kill it.
If this answer is acceptable please remember to return and mark it.
Score 1
Voeg je antwoord toe
asahi21 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 10,316
