How can I replace a cut Intuos Wacom pen tablet PTZ-930 power cord?
I know I can join the four colored wires but not sure about these fiber/wires?
Is dit een goede vraag?
It looks to be a USB cord. So it should be fairly simple.
Find a USB cable that you don't use. You will need to cut off one end (the side that doesn't connect to a computer). Then just match up the wire colours and solder them together.
Was dit antwoord nuttig?
I know I can join the four colored wires but not sure about these fiber/wires? (check out the newer pix i posted) Thank you for the response btw!
That is just shielding. If that's on the new USB cable don't worry about it, Just make sure it doesn't touch the other wires at all. Cut it back away from the others.
omg that is all I wanted to hear!! THANK YOU SO MUCH!
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,722
