Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
Mute button wont switch
I'm having trouble with the Mute switch.
I've got the red line of the button on top, as for the switch i've also put that one above.
Cant seem to get this to work.
Did i put it in iTS right position?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
A pic would help
Are you saying that when you reassembled it won't work?
Was dit antwoord nuttig?
1 Opmerking:
I uploaded a picture of the bracket for the mute switch.
I think i need a holder for this bracket ,can someone confirm.
Lost this when i replace the upperflex cable.
door
That bracket needs glued or adhered to the flex cable
Like this
1 Opmerking:
I uploaded another picture.
This is the other Side of the bracket.
This Needs to be like this?
I put the button red line on top of the button.
Also the switch was in the upper position.
This is correct right?
Somehow i cant get it to work and i dont know why.
As for you picture, do you mean that i need to Glue the switch from the cable to the bracket?
I'm going crazy on this thing.
door
That metal bracket should be stuck to the flex cable and the position of the switch should be down.. It can be tricky
Voeg je antwoord toe
Xander Tempels zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 131
