Ga door naar hoofdinhoud
Handleidingen voor het repareren van tweewielig, gemotoriseerd vervoer, inclusief bromfietsen en scooters.
564 Vragen Bekijk alle
Vraag afgerond
How much transmission fluid for a Harley-Davidson Sportster?
How much many bottles of transmission fluid do I need to use? Please
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Here's a link to the owner's manual which says: "Add 1.00 U.S. qt 0.95 L of GENUINE Harley-Davidson FORMULA+ TRANSMISSION AND PRIMARY CHAINCASE LUBRICANT (Part No. 98851-05 qt) through clutch inspection cover opening until the lubricant reaches the bottom of clutch diaphragm spring." under the "Changing Lubricant" section.
Was dit antwoord nuttig?
Score 4
Trina,
The Sportster should take around 25-30 oz. You should check with your service manual to make sure. Otherwise you can also call in a local Harley shop and inquire.
Best of luck!
Score 1
1 Opmerking:
Sorry, forgot to mention that its somewhere between that amount because it depends on the year of your sportster. You can start with 1 bottle or 1Qt. and then work from there.
door
I got my Harley Sportster service manual from TheManualStore.com. I use it ALL THE TIME.
Harley Davidson Sportster Manuals
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 2,389
