Ga door naar hoofdinhoud
De derde iteratie van de 10,1 inch Galaxy Tab-tablet.
Why did my home button stop working?
Ever since I replaced the charging port and flex ribbon, the home button stopped working. Did I lose or damage a piece? If so, what is/are the piece(s) called to that I can order and replace?
Is dit een goede vraag?
Score 11
1 Opmerking
you just need to reattach the ribbon properly
door
Voeg een opmerking toe
16 Antwoorden
Het nuttigste antwoord
Had the same problem after a battery change
Found that gold ribbon on left and black main ribbions white line where not aligning with gold line on board
Going straight in was not working
Going in at a slight angle with a push and a wiggle
Got all lines aligning
Hope this helps
Was dit antwoord nuttig?
Score 4
Okay, so I had the same problem. Only the back and open apps buttons worked. Went back in and realigned lines on the ribbon cables with the lines on the circuit board and BAMM, the home button works..
Score 3
Hard for me to recall. I think that the home button ribbon plugs into the charging port on that one. So you may just need to make sure they are plugged in all the way.
Score 2
No usefulness to this if you have to build a reputation to vote down unhelpful advice
Score 2
This one was an easy fix for me.
The connection to the mainboard is where the problem is.
There is a line eitherside of the ribbon cable, make sure the mark on the ribbon cable lines up with the ones either side.
Score 2
1 Opmerking:
Home button stopped working after USB ribbon cable replacement. This was the fix for me. I had replaced the USB ribbon cable but had not fully inserted the cable into the connector on the motherboard. Cracker666 correctly points out that the horizontal line at across the end of the ribbon MUST align with the two marks either side on the main pcba.
door
I noticed the same thing. I found the fix if interested still. There is a little piece that you have to put back under the plastic tab connected to the USB part. It must get connected back to the other connector part hidden under the plastic casing (tab).
Score 1
I replaced the same part a d now have the same issue. Did you find a fix
1 Opmerking:
yes....just make sure you reattach the ribbon properly
door
Home button back,search all button not to work can u give me a solution of this problem?what can i do?tell me answer
1 Opmerking:
The answer are in the comments up there bro....
Just make sure you reattach all the cable/ribbon properly in placed. If still not working...you need to replace it with new part
door
Do not push the ribbon all the way in, stop a little before the white line. If you push it too far it will not make proper contact with the connector. ;)
My problem is that after time out of the screen,pressing the home button does not bring bacķ the dispĺay.The screen remains ďark no matter how many tìmes i press the home button.The only waý tò access the data again is to restart the computer again
2 opmerkingen:
Anybody know where I can get a ribbon cable for my home button?
door
Anyone know where I can get a ribbon cable for my home button. Galaxy tab 3 7.0
door
I have the same poblem.
When l put back the old charge cabel the home button works fine.
The old cabel has 1.1 vesion and the new one has 1.0 on it.
l think thats the poblem...
Under the plastic framework at the bottom, where the micrphone ribbon goes, there is a tiny rectangular connector from the home button, another ribbon. This connector plugs into the end of the ribbon that has the microphone from your new charging port.
1 Opmerking:
I checked the ribbon to main board a dozen times, and no fix. This above was a 100% fix.
door
My tab home key stop working
Does anyone have a picture of the connector? On mine the leftmost pins seem to be missing after sending it in for a battery replacement (Note Pro), and now the home button doesn't work anymore . Charging is intermittent.
1. How to settle home button galaxy tab4, the button inside, stuck, cannot push. The charger still good condition?
2. How to reset for password forgotton without use home button?
indeed easy fixed by reattaching the cable while wiggling it a bit.
Voeg je antwoord toe
Christina Yung zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 35,177
