Ga door naar hoofdinhoud
De LG VX5200 is een CDMA-klaptelefoon met een externe antenne, 32 MB aan intern geheugen en een 1000 mAh Li-ion-accu.
Will I erase my text messages if I repair the logic board
The piece that connects to the charger is broken and I desperately want to recharge my phone to access my old text messages. If I replace this piece on the logic board will this erase my phone's memory?
Is dit een goede vraag?
1 Opmerking
Im having a simular issue but with a note 4 antenna port. So I replaced the charge port, the glass back (which cracked when being opened), and the charging port but in the process of putting everything back together again for the 3 time. I broke the antenna cable port when snapping off of the motherboard logic board. The antenna cables are fine but the port that the cables snap on to are broken. Does anyone know how to fix it or if I replace the whole part, will I still have my text messages and stuff?
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Trevor, no it will not.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Thanks. Is there a way to just transfer my phone's memory to another VX5200 that works? Or would it be smarter to replace this one piece? Or should I just replace the whole logic board?
Thanks
-Trevor
door
Trevor, ""Is there a way to just transfer my phone's memory " only if you know how to reball a BGA IC. I suggest you get a charged working, start your phone and transfer your files to another device (computer) than you can either resolder a charging port or replace the board. This will depend on your skills and $$$
door
Thank you. I have no soldering skills, and dont know how to reball a BGA IC. What do you recommend? I just want to read my old texts, see pictures, and listen to voicemail messages. -Trevor
door
door
Voeg je antwoord toe
Trevor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 827
