Ga door naar hoofdinhoud
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Vragen Bekijk alle
My iPhone wont turn on it is stuck on the apple logo
i dropped my iphone in the toilet and it was working for awhile but then i turned it of to restart it but now it is flashing from the apple logo to black when it is plugged into the chager but when i take it off it goes black again.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The inside of the phone probably has corroded a bit. Over time the corroded components and become more damaged. You would need to take it apart clean it with a toothbrush and rubbing alcohol. See if that fixes it. If not then you can see if one of the parts need to be replaced.
Was dit antwoord nuttig?
Score 1
need new battery also if its doing boot loop clean it with 70% acohol
1 Opmerking:
use air duster to dry it the reason you use acohol instead of anything else is acohol has a quick drying time
door
Voeg je antwoord toe
alie123 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 3,627
