Ga door naar hoofdinhoud
The Huawei Ascend P7 is a 5" smartphone released by Huawei in June of 2014. Model numbers: P7-L10, P7-L00.
39 Vragen Bekijk alle
Black screen Huawei p7
My huawei p7 has a black screen and it doesnt respond anymore when i hold the power button it vibrates 1 time and when i put it in the charger my red light works on the phone and i dont know what to do because my warrant is not valid anymore somoene can help?
Is dit een goede vraag?
Score 22
20 opmerkingen
Similar problem. The phone does not power on, I just have the front led flashing a red light, then an orange one , and eventually a green light.
door
I have the same problem.. please help!
door
Me too have same problem... I am worrying a lot. Just used for a month and now no more use :(. Even in warranty, I am in USA and no service center too :(
door
Buddy, the screen itself not turning on but inside I feel it is functioning, if some one calls it is ringing but I could not seen anything in display. It is totally black
door
15 commentaren meer tonen
Voeg een opmerking toe
10 Antwoorden
Het nuttigste antwoord
I had the same problem and just opened the sim and sd cards and put them back in again. It came back on again. What a relief!
Was dit antwoord nuttig?
Score 6
7 opmerkingen:
Thank you so much. Problem solved.
door
i tried but same problm
door
worked as soon as i took out the cards
door
I will try this, I hope it will work
door
i have tried all the methods nothing worked even toke the battery out nothing work still the phone is working but black screen
door
2 commentaren meer tonen
my phone have a this problam
helllllllp
1 Opmerking:
I had the same problem.my phone doesnt switch on and its only blinking in red
Please help.thanks
door
Remove the back cover to check if the screen connector gets loosen and try to re-connect
2 opmerkingen:
and how do you do that?
door
yeah his right, how can you remove the back cover ?
door
guyz my screens only shows up during calls and when i unlock my phone. After unlocking my phone the home screen gets black and can see the bottom 3 options and can use the top slide as well but can't assess the app's that are on home screen ??? plzz help me out
lol i just changed my home screen style from top slide setting and issue resolved : D now.
no more black home screen............... wew
1 Opmerking:
really, that great
door
You need to flash your Huawei P7 Device using P7 Firmware, download P7 Firmware from google, and flash with that. Can you access to "Recovery Mode" ?
I can her mine but I can't see nothing
my Huawei p7 lite is black screen can’t open but I charge the it have the led light and sound others things is nothing just the screen always black screen.how to fix it
1 Opmerking:
I have exactly the same issue ;(
door
Please my Huawei Phone is on the power button isn’t working, the phone is on, as I keep hearing notifications but can’t open it, HELP!!!
ASSALAMUALAIKUM in my p7 phone there is a problem the problem is my phone is not charged and not open some days ago my phone is on but there is a line colour green but my phone is not on plz help me
Voeg je antwoord toe
MsMoha1997 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 13
Altijd: 31,912
