Ga door naar hoofdinhoud
Reparatiehandleidingen voor de verschillende uitvoeringen van de Compaq Presario CQ62 laptop. Dit merk werd gefabriceerd van 1993 tot 2013 en was eigendom van HP van 2002 tot 2013.
there is power but only a black screen
it turns on but it's only a black screen and the cap locks keeps flashing
Is dit een goede vraag?
Score 13
3 opmerkingen
My screen is black the windows logo comes up but then it goes away and the screen is black can I fix this
door
How do I get my screen to come up
door
My compaq 160 black screen
door
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
Sammy Soto, try this firs. Disconnect all power sources, battery, plug, usb devices, then hold down the power button for a minute to clear residual charge. this should reset your bios. If it does start up go to the diagnostic tab and run the hard-drive and memory Tests. See what it shows. This could be as simple as a bad memory module to as bad as a failed CPU. Check here for the blink codes. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 3
10 opmerkingen:
Thank you. I had the same problem. Did what you explained and it worked! I really appreciate it. G
door
Me too! Thanks a lot. As a non-techie person, I appreciate not having to go to the repair shop.....again!!
door
doesnt work for me any other tips?
door
billyjoewitehira, same blink codes? You tried an external monitor? what have you tried?
door
Worked for me thanx
door
5 commentaren meer tonen
I came upon this question a bit late. If you have no display when powering up the laptop on both the built in LCD monitor and a monitor connected to the VGA port the issue is a bit more serious.
The cause of the issue is a clogged radiator in the exhaust fan.
That being said depending on how quickly you address the issue the fix can be simple or quite complex.
Either way you will be disassembling the laptop and removing the cooling fan and heat pipe assembly from the mother board. With the assembly removed clean all the old heat-sink compound from the two (2) heat sinks on the cooling pipe assembly as well as the two (2) ICs they mount to. Disassemble the fan and with a soft brush or "canned air" completely clean the radiator fins.
If the problem is addressed right away by cleaning about 6 out of 10 machines need nothing else but reassembly with fresh heat-sink compound applied.
If the problem is not addressed right away the repair is not for the feint of heart.
To repair- After removing the heat pipe assembly mentioned above you will see the CPU an a smaller IC on the mother board. You will need to use a hot air or infra red reworking station or it's equivalent to heat the smaller IC (it is your graphics processor) to about 200- 220 degrees Celsius for two (2) to three (3) minutes to re-flow the solder connections and then reassemble as above.
All that because the fan was clogged and has heated the graphics IC enough to loosen the connections between the motherboard and the IC.
Hope this helps you fix the problem and understand why it occurs.
PC fix mantra- Clean your PC cooling system and back up your data regularly.
Score 3
2 opmerkingen:
It worked. Now computer is up again.
door
I need to knpw whic IC to heat up, is there ap picture of it, I dont want to heat the wrong one.
door
Change CR3032 battery, my computer been black screen for months. I've done hard reset until it stop working. Decided to check it with another monitor and it was working. Disconnected from monitor went back to black screen. Took back off seen the coin battery replaced it been working ever since.
Score 1
1 Opmerking:
This worked perfectly! Thank you!!!!
door
Voeg je antwoord toe
Sammy Soto zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 33
Altijd: 24,168
